Use the following procedure to verify the proper global SPBM configuration.
Switch# show isis spbm ============================================================================================================== ISIS SPBM Info ============================================================================================================== SPBM B-VID PRIMARY NICK LSDB IP IPV6 MULTICAST SPB-PIM-GW STP-MULTI INSTANCE VLAN NAME TRAP HOMING -------------------------------------------------------------------------------------------------------------- 1 4051-4052 4051 disable disable disable enable disable enable ============================================================================================================== ISIS SPBM SMLT Info ============================================================================================================== SPBM SMLT-SPLIT-BEB SMLT-VIRTUAL-BMAC SMLT-PEER-SYSTEM-ID INSTANCE -------------------------------------------------------------------------------------------------------------- 1 primary 00:00:00:00:00:00 -------------------------------------------------------------------------------- Total Num of SPBM instances: 1 --------------------------------------------------------------------------------
Switch# show vlan basic ===================================================================================== Vlan Basic ===================================================================================== VLAN INST ID NAME TYPE ID PROTOCOLID SUBNETADDR SUBNETMASK VRFID ORIGIN ------------------------------------------------------------------------------------- 1 Default byPort 0 none N/A N/A 0 CONFIG 10 VLAN-10 spbm-bvlan 62 none N/A N/A 0 CONFIG 20 VLAN-20 spbm-bvlan 62 none N/A N/A 0 CONFIG 100 VLAN-100 byPort 0 none N/A N/A 0 CONFIG All 5 out of 5 Total Num of Vlans displayed
